AdvancedHMI Programming Question
aiki202
Aug 2007
Pennsylvania
178
I have been developing an HMI application using the free AdvancedHMI application, VB.NET Express, and a MicroLogix 1200. I cannot get the ReadAny function to pull in any data from the PLC. The WriteData function works fine. I'm not sure if I am doing something wrong, or if the way I am using the function will not work. Here is my code:
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
Label5.Text = DF1Comm1.ReadAny("N7:0")
End Sub
I am trying to pull data in from a standard button click event into a standard label. Is this possible?
No error messages appear. The application continues without a problem, but the actual integer value from the address is not updated. I single stepped (F8) through ever step of your code that reads the integer, everything "appears" to work properly.
I would like to temporarily install AdvancedHMI on the same computer as FactoryTalk View SE. I am waiting for another contractor to finish the FTV...
561
Hi all, just wanna ask if anyone has used an M221 controller and successfully connected to AdvancedHMI
1,318
MessageDisplayByValue question is there a way to embed a tag value in the messages of the MessageDisplayByValue function ??? Similar to what is...
2,832
Hi All I have been switching between 2017 and 2019, all depending on which one i found more stable, at the moment I use 2019 I was just...
1,482
I tried to use AdvancedHMI as a Modubius Client and it does poll the data from a Modbus server. But I am unable to use AdvancedHMI as a server...
3,060
