After installing Step 7 V5.4 SP3.1 my CP5512 doesn't work any more.
pietervdb
Jun 2006
Ghent, Belgium
67
Monday i have downloaded the new update for Siemens step7 (SIMATIC_S7_STEP7_V54_SP31_alone.zip) because i still have some problems with SP3 and WinCC Flexible 2005. The installation goes without any problems.
Thursday when I try to connect to a CPU with my CP5512 PCMCIA card I get an error.
When I look at the “Set PG/PC interface” is see a yellow dot with exclamation mark in it next to my CP5512 interface.
I though maybe the driver is corrupted when installing SP3.1. So I deleted the interface in the device manager and reboot my system. My system found new hardware but it couldn’t recognize it .
I called the Siemens hotline but this is there answer that didn’t worked for me.
* Deinstallation des CP5512 aus dem Windows Geräatemanager (device manager van windows)
* Entfernen des CP5512
* Entfernen alle Registry-Folder unterhalb folgendem Verzeichnis, die CP5512 im Namen haben:
HKEY_LOCAL_MACHINE\SOFTWARE\Siemens\SINEC\LogDevices
* Neustart des Systems
* Stecken und Installieren des CP5512 (automatisch)
Does anyone has another idea?
We just got the link to download and install Siemens Step 7 Pro, v17, and WinCC Comfort v17. My needs usually involve using earlier versions for...
5,271
Hello, Today I install Siemens PLC software SIMATIC Step7 v5.4. after installed, I start SIMATIC manager. it pop up "Run-time error 35600, index...
10,185
:banghead: I have (finally) managed to install Step 7 2006 professional SR2 on my PC at work. I say finally because it was a difficult install...
1,885
Hi. I am trying to install Step 7 v5.3 on XP Pro. I have all the latest windows updates. The software just hangs up during the install. There are...
3,666
Hi All, I have a problem installing Step 7. I got Win XP SP1, Step 7 V5.3 incl. SP2. I have had install the software a year ago and since then...
3,895
