Aga3 flow calc in rtu
An RTU is an RTU. A PLC is a PLC.
Doesn't the RTU have the AGA 3 calc built-in?
Here's Emerson's white paper on the AGA 3 calculation:
http://www.documentation.emersonpro...documents/instruction_manuals/d301224x012.pdf
Anyone have a function block or structured text routine they would like to share for the logix series plc? Figured I would ask before I put...
1,333
Hi, I am writing a Controllogix program to calculate gas flowrate. I need the flow calcualtion for AGA3 standards. I have looked at the...
5,507
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
144
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
149
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
59
