AGA3 Flow Calculations
HLeap
Jun 2005
Texas
55
I am writing a Controllogix program to calculate gas flowrate. I need the flow calcualtion for AGA3 standards. I have looked at the publications website for AGA and I am confused as to which book/manual/document I need. I could buy the whole set but at ~$800 it is a little expensive when all you need is the actual calculation with an explainition of the variables. I called the 800 number for the website and entered the number in the automated menu for "Techinal Support". The response I got was "We are just a bookstore for AGA...I have no idea what you are taking about!"
Anyway, if sombody could guide me to the publication I need or refer me to a website that shows the actual calcualtion I would greatly appreciate it.
Howard
Several references to AGA 3 in papers on this site: http://www.ceesi.com/pubs_orifice.aspx
specifically,
Effects of abnormal conditions on the Acuracy of Orifice Measurement
or
New Data for the Quadrant Edged Orifice
It appears that ANSI/API 2530 might be the same, which might broaden your search possibilites.
Check this link.
If this has anything to do with custody transfer or check metering, you're probably wasting your time.
You can get a flow computer module from ProSoft to go directly into your 1756 chassis.
I found this webpage that may be useful.
I'm supposed to be doing the same thing, but I'm leaning toward a dedicated module. I don't have the local engineering resources, nor the time, to figure out what I need to do to make this work in my application.
We're using chart recorders right now... :nodi: they're getting by.
Anyone have a function block or structured text routine they would like to share for the logix series plc? Figured I would ask before I put...
1,335
Anybody here implemented the AGA3 flow calculation in PLC and any free calculation tools is availbile for free:mddr::mddr:
2,627
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
144
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
151
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
60
