Alarm Display not working after import
krishna431
Jan 2017
New York
32
Hello everyone. I was working on a test application in Wonderware InTouch using both AlarmDBViewCtrl and Distributed Alarm Displays. Once I got the alarms running the way I wanted, I imported that window and its scripts into an existing InTouch application on the same computer. However, in the new application both the alarm displays are empty and nothing is written into them. I keep getting two pop ups from InTouch which I have attached below. Can anyone help me figure out what the problem is?
Here's some answers to some basic questions you may have:
- Yes, I declared the bind list for the second application.
- Yes, the name of the alarm OCX's that I'm using are the correct ones.
- Yes, I have all the imported tags declared in the tagname dictionary.
- Yes, both the applications are running on the same version of the software.
I figured out the reason why it was not working. I had not set an alarm state in the discrete tag used for writing into the alarm table. Now it is working fine.
First time using a panelview. I have all of my alarms mapped to bits of dints. How do I get the alarm panel to popup when an alarm happens...
2,125
I am trying to have my Alarm Summary page open when an alarm goes active (I am using ALMD blocks) this is the expression I am trying to use...
1,232
I use PanelView Plus 7 Graphic Terminals Model: 2711P-T10C22D8S-B PLC: Compact Logic 1769-L36ERM Tag ER[4].8 -> ON, the message is "1046 Abnormal...
1,763
I’m finishing up a PAC project and one of the the last things I need to take care of is setting up all of my alarm points in PAC Display...
1,179
Hello guys, I just started my first project with factorytalk view studio, and ran into a problem, if guys have any suggestions please help me. so...
4,123
