Alarmlist-coloring bug in Panelview Component
crawler009
Feb 2012
Planet Earth
239
Hello,
I use all Alarms without Ack.
My colors are: Red for "Active No Ack Req BackColor" and White for "Inactive No Ack Req BackColor".
Under nomal conditions, if a alarm is still on, it is Red. If its gone, it turns White.
The problem is with the restart of the mashine.
For example, i have a failure on a component, lets say valve 1. In the Alarmlist i have "Fault valve 1" in Red.
Now i restart the mashine. Now i have 2 Times "Fault valve 1" in Red. When i repair the valve, the fault bit goes away and the last "Fault valve 1" turns White.
But the second last (that was before restart) "Fault valve 1" is still on Red. It doesnt turn into White, and it seems that there is a active alarm, but there isnt.
Another example: I have a failure on motor 1. In the Alarmlist i have "Fault motor 1" in Red.
Now i turn off the mashine to change the motor. When i turn on the mashine, the fault bit (from the plc) is gone, but the Alarm "Fault motor 1" is still in Red, and there is no way to turn it into White. The customer thinks there is still a problem with the motor, but there is no.
Has anyone a solution to this problem?
Best regards,
crawler009
Hello, So I have a 1769-L16ER AB controller (firmware 32) connected to a PanelView Plus 7 Standard (firmware 12). When I change to a screen with...
2,521
Having text cut off on an alarmlist message. Other than abbreviating the message, is there a way to word-wrap or loop/scroll/marquis the text?
1,565
Hi! A old customer called me and he had bought a used machine. The machine was equipped with a Siemens PC670. He was not at the site today but...
1,998
Hi, I've been reading through IEC 60204-1 and NFPA 79 recently and came across a table about indicator color coding (chapter 10 in both...
3,333
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
181
