ALG 391 Output module
jcp
Feb 2010
Multan
369
Hi friends;
I use IC693ALG391 output analog current module as a voltage configration as per GE documentation. But the problem is that at 32000 count it gives me 4.78 volt instead of 5 volt.
is it correct?
Regards
Hi experts; I have a module ALG 220 4 channel. When i add it into chasis and go to I/O configration there is only start adress and size. But i...
2,261
i have an electronic card which its output is analog 0: 10 vdc this analog output is connected to an AC DRIVE as ALTIVAR 16 from telemecanique...
31
11,992
Hi all, So I've got an existing 10 slot rack with a IC693CPU374. Popped in a new 2 channel analog output, configured it, downloaded the config...
1,631
Hi friends; I use one channel of ALG391 Module for 4 to 20 mA. Can i used second channel for 0 to 5 Volt? Regards
2,341
Hi experts; Can i use one channel for voltage output and the other for current of ALG391 output module which used in GE fanuc 90-30 series? regards
2,189
