magdyfayad
OP
first thanks for your helps
the AC drive Altivar 15 is an old and do not change drom 16 years and also no kepad program as the keypad program is an optional for Altivar 16 and we did not have it , so the Altivar 16 is an old AC drive , the new project only for Optimove 1 instead of PRC1
the two prjects are identical for 15 years ago , as the only change for PRC1 to Optimove 1 for one project only
I contacted with ITWGEMA from Swizwerland yesterday , and till now no solution from them ,
i found the Run signal and the direction signal ( but i m not sure now the postive or the negative ) both Run and Direction are continous 24 vdc !!! , this note also in the old project use PRC 1 and Altivar , so i can not prevent neither the Run signal nor the dierction signal !!
i know the normal case there is a run signal must come from the the PRC1 or the Optimove 1 when we push start key only , but i found as i said both Run signal and the direction signal is continous 24 vdc !!!
so the only method i use to prevent the anlog output only ,- but also it must be zero voltage at the power up -
but this is the only method for me now that i can to prevent the motion of the motor at the power up ,
but then the another problem appeares to me : on - off on - off relay at the rest of the motor only
thanks again for your cooperation
wait again for your responses
