all about sysmac cqm1
DEVITG
Aug 2003
CORDOBA ARGENTINA
18
My customer ask me to handle the following PLC
SYSMAC CQM1
OMRON
PROGRAMABLE CONTROLER
PA206
CPU21
All I know : it is a PLC handling a wiegth and filling machine of french fryes and snack chips.
My need is to get or buy the software , cable and interfase.
On of my worst concerns is that it seem to be runing under MAC/
Could it be so?
I only handle WIN or Dos
Hello Gabriel;
Use the Internet link in the attached picture to look at more support info from Omron.
Hope this helps,
Daniel Chartier
dchartier is right. CX-Programmer is the current version of Windows software available for Omron PLCs. You will also need a CQM1-CIF02 programming cable if you want to use the periphearl port. IF you can use the serial port, then you need the C200HS-CN220-EU programming cable. Either one will work.
See if you can contact my good friend Roberto Colatruglio at Omron in Buenos Aires. Tel him Jay sent you.
Roberto Colatruglio
Omron Electronics, LLC
Industrial Automation Division - Region Cono Sur
Ing. Butty 240 - Piso 5 - Of 501 -
(C1001AFB) Buenos Aires, Argentina
Tel: (+54-11) 4590-2408
Fax: (+54-11) 4590-2401
Dears, i have a problem with a labler machine .the problem is when we try to run the machine ,the machine not respond . when we checked the plc...
6,031
Hi All Iam using plc omron (sysmac cqm1 cpu 11), i have a problem on out put module (oc222)and want to replace the module, my problem that...
7,015
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
586
