SYSMAC CQM1 OMRON problem
johneedw
Oct 2009
asia
204
Dears,
i have a problem with a labler machine .the problem is when we try to run the machine ,the machine not respond .
when we checked the plc system (SYSMAC CQM1 OMRON) we found that the red led of (COM2) port is blinking which is connected to the (VT510) pannel .also, the(VT510) pannel working with itallian language while we need English language!
Please , advice me to solve this problem and help us to change the language to english.
NOTE: the plc in RUN state and the inputs/outputs leds are in normal case, also, the VT510 unit is functioning and there is no alarm massege yet!
Red Light is an error (not good) could be either port, most likely the cable/connectors.
Language is a bit harder you will need to retype all the text, you can have several languages, Red Lion is the only one I know that will translate for you.
Hi All Iam using plc omron (sysmac cqm1 cpu 11), i have a problem on out put module (oc222)and want to replace the module, my problem that...
7,014
My customer ask me to handle the following PLC SYSMAC CQM1 OMRON PROGRAMABLE CONTROLER PA206 CPU21 All I know : it is a PLC handling a wiegth...
5,180
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
579
