Allan Bradley Micro Logix 1500
Screamtruth
Jul 2005
Houston, TX
Anybody have any good training resources on this unit, besides the manual? I have limited PLC training, but will be attending a class covering Allan Bradley units. As far as I know, the unit is interfaced with a DAT module which I think allows the user to change the I/O or ladder logic in the unit. Is this right?
Since I will be using this PLC for a while, I'll be a frequent on this forum.
Thanks in advance for any help
Its called a DTAM not DAT, Data Table Access Module, it can be used to access and change data, what can be changed depends on the type of DTAM module.
Hello, I have a problem with an error that appears when I load the software on the PLC. I'll attach a picture of the error window, but basically...
385
Hello all Is it possible to configure an 'Object' to feed data from one PLC processor to another PLC processor? I would like to send data from a...
2,854
Hello, Pls we are using the above PLC to control the seeder unit at work. It is a touch screen only, but now some functions can not be reset by...
1,144
Hi All, I've been using GE and Siemens for a long time and just switched to Allan-Bradley because of one of our customers requirements...
21
4,590
Good day all. This may not be the proper forum for this question but I will through it out just in case: I have an E-beam welder that has an...
1,350
