Allen Bradely PLC communication Using NAT Configuration
bansodevb
Jan 2010
India
28
Hi All,
I want to exchange data between Controllogix L72 and Compactlogix L32E.
Both PLC's are on different Ip addresses.
Controllogix IP : 10.20.135.216
Compactlogix IP : 10.0.1.1
How can I exchange data between two PLCs using NAT?
Thanks In advance
Vinod
Hi
I have used Allen Bradley 9300 -ena
A factory I work in had this as the site standard.
Now it's not cheap but it does work and is very easy to set up
Donnchadh
Hi
You could also add another Ethernet card to the l72 rack and use this card as part of the l32 network
Donnchadh
You can use a PC running windows (if one is available). We have a .net class or a really inexpensive activeX for clogix that you can use to exchange any kind of data between the 2 PLCs. You can also use another Ethernet module in one of the 2 PLCs. Both solutions will use another layer of hardware. For .net solution, get it from our web site www.controlsystemtools.com. If you have questions, contact me. Good luck.
[email protected]
Hi Donnchadh,
We are trying to communicate using 9300-Rades with no success.
Have you used 9300-Rades in any of your system configuration?
Do you have any document for 9300-Rdes configuration.
Thank you in advance.
Vinod
hi all, which AB PLC or module that runs on BASIC language? thanks
3,561
In order to establish communication with A-B PLC 2/30 and be able to read /write data from/to this PLC using OPC server we have established a DH+...
3,565
Dear all, Actually I am not familiar with Allen-Bradely PLCs but now we have to figure it out how the PC sends data stream to Allen-Bradely PLC...
4,858
Can it easily be done ? We have a legacy project written on Allen Bradly 1746-l542 with Several racks of some on an extension rack and some on A...
1,753
Hi all, I have 2 MER files that we compare quarterly to try capture any changes that have been made to HMI files. The files are identical, same...
1,480
