Allen Bradely problem
MAHER
Jul 2007
CAIRO
82
Dear All,
after installing " RSLogix 5000 v20 & v19 "
i created program by " v20 " , after that i tried to add new module by the following steps:
_ I/O configuration folder
_ Right click
_ Add new module >>> but i found this this word not active
i repeated the previous trial by using " v19 " , i got the same result.
so please could any one tell me why is it happened , and how can i over come this problem.
Thanks In Advance,
maher
I assume you had to select a processor when creating a new project. If you expand the I/O Configuration folder The processor should show up on a bus (mine showed up on 1769 bus since I selected a 1769-L2ER-QB1B CPU) and right-clicking on the bus should provide you with 'New Module'
yes of course when i created the new project i selected the cpu " any cpu " just to test the software but nothing changed
I'm using Studio 5000 to create a new project and 'any cpu' is not an option. Adding I/O modules is somewhat related to the type of controller you select and the backplane or bus it resides on. I think you'll have better luck if you select a real CPU...
I did as you told but nothing changed
i thing the some thing like hardware not installed i don't know i don't know
Go to Help then About RSLogix 5000. At the top it will say something along the lines of: RSLogix 5000 Professional Edition, or Service Edition or some other edition. Which edition do you have?
OG
Dear Friends, Myself Abhishek Desai and i have one query reagrding RS Logix 5000. As i am working with Festo, i got on display 79 no. insted of...
4,209
Can it easily be done ? We have a legacy project written on Allen Bradly 1746-l542 with Several racks of some on an extension rack and some on A...
1,770
hi all, which AB PLC or module that runs on BASIC language? thanks
3,570
Hi all, I have 2 MER files that we compare quarterly to try capture any changes that have been made to HMI files. The files are identical, same...
1,496
Hi all, how many plcs can allen bradely panel view hmi connect get data for mimics
16
7,114
