Allen Bradley 1756-M02AE axis servo loop error
rvtran
Jul 2013
San Diego
Dear All:
I have the flashing red light on the FDBK indicator. The manual said that it means:
The axis servo loop error tolerance has been exceeded
I do not know what causes it. Does anyone have this problem before?
Please Helps.
Thank you
Dear All:
Please Helps.
Thank you
Hi there I have same problem did you fix it and can you share how???
Fault means the position error has exceeded the limit set in the axis. Which means the feedback is not following the commanded analog position of the axis. Could be an encoder issue, slipping of the encoder, or the axis isn't physically able to move and follow the commanded position.
459
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
169
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
251
Hi Guys, Here I have Started to work on some difficult task I hope I will get some solution here. I wanted to communicate ABB CI 840 IO Master...
929
Electrical simpleton here, so show me mercy. Plant previously had a 4-20ma valve that was controlled via pneumatic controller with a P/I. Now...
3,147
