Allen Bradley 1794 AENT Flex Module
Thanks for all your replies.
I have changed the Flex adapter module with a new one. No bent pins, but still the module keeps faulting.
Okie, I have monitored the status of the module in RS5000 but although the yellow exclamation marks come in my I/O tree the module properties status always shows running.
I have attached a copy of the RSNetworx file for the ethernet network.
When I get to work I will go online and get the rest of the information you have asked for.
Mark
It may be a network switch port is bogging down and then quickly coming back up. Try running a continuous ping thru the switch to the module address and look for inconsistent response times. To run the continuous ping type ping 10.64.8.103 -t at a command prompt. Control^C will stop it. If the response times jump around quite a bit or you get a few "no reply" responses then try rebooting or replacing the switch, or moving the module to an unused port.
First of all, I'm new to Allen Bradley. Have almost exclusively worked with Siemens before. I'm trying to add a new IO station to the my...
16
5,940
I have a ControlLogix system that has a few Flex I/O over contorlnet. I want to setup a device that requires ASCII data to be sent to it...
5,553
Regarding DeviceNet programming, the manual doesn't have much with regards to DNet. It's a pretty simple feet/minute application (and only about...
4,587
Any one give solution for this fault. We are using AB Gaurd logix controller(5573s), resent days we are facing major fault in controller...
87
Hi how's it going. Was just wondering if someone could help me out. Recently one of the guys over on the LinuxCNC forums put me onto getting an...
356
