Allen bradley 5/40 to RSlogix communication interface
Ankursood
Apr 2012
Gujarat
in our plant we want to have a communication interface between allen bradley 5/40 & Rslogix via IO adapter i just wanted to know whether anyone has worked on this type of communication earlier and were they successful.
Also the hardware required for that
You cannot perform "ad-hoc" communications on a RIO network. There are just no methods available for sending or receiving user data, RIO was designed exclusively for I/O data.
What is the full part/model number for your "PLC 5/40" - that is a bit like saying "I drive a Ford" - be specific.
What is the "RSLogix" you refer to - RSLogix is a Rockwell Software product, in this case I suspect a PLC programming software, but which one ? RSLogix5 for the PLC5 series ? RSLogix500 for the SLC500/Micrologix series ?, or RSlogix5000 for the Logix5000 series (ControlLogix, CompactLogix, FlexLogix, DriveLogix, GuardLogix, SoftLogix.....).
Hello all. I have been working with an SLC 5/04 system, which houses various Digital and Analog INs and OUTs, up to Slot 29. I am currently...
2,519
1.the black switch is master start/stop switch 2. When red pushbutton is pressed once, both motor 1 and 2 should run continuously 3.if you close...
1,755
how can i use my allen Bradley RSlogix PLC to gate triggering to a TRIAC or thyristor actually i want to gate triggering to the TRIAC or...
6,261
Hello All, I am fairly new to PLC programming and really only know how to use the basic functions of RSlogix 5000. I have a new project I will...
24,381
Hi All, I wonder if anyone knows the answer, or even if its a stupid question, as to whether the ALMA / ALMD blocks that rslogix uses for alarms...
6,299
