Allen Bradley 6200 Software
Russell
Dec 2004
I have a problem were I need to use Allen Bradley 6200 software to communicate with a PLC5/40B processor via a modem. I am using a westermo TD-32 modem at the PLC end attached to channel 0 and a standard external modem at the PC end attached to com1. I cannot get the 6200 software to use the modem correctly?
Has anyone done this before?
Thanks a lot RSDORAN that did the trick. I tried it again after getting some ideas and it worked first time.
6200 programming software
Hello Russell!!
I have a PLC 2/30 allen bradley, but I can´t find the 6200 programming software. I have a difficult with this. Do you know some program like this? Could you give me the 6200 software? Excuse me for this, but I don´t know what to do. Thanks a lot
Even old software is not allowed to be distributed without the original vendors accept.
This company makes an alternative software for PLC-2, including the necessary online cable:
http://plc2software.com/
Apart from that, your PLC-2 is long overdue for a replacement.
The inevitable replacement may be far less expensive than continuing to support an arcaic PLC.
Also there was A.I. 2 software that woould work too. But it's not free either. Replace that 2/30 now!
Does anyone have the installation files only (not the license) for the Allen-Bradley 6200 software for the PLC 5/250 (also known as Pyramid...
1,226
Hi, I was looking for some help on configuring a 1784-PCMK Version A card to work with Allen Bradley AB6200 software in Dos, to connect to an AB...
3,318
I'm trying to access our extruder 6200 allen bradley plc-5 unfortunately I can not perform online program. A message keeps appearing "BAD...
4,300
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
147
421
