Saurabh Trivedi
Hello All,
I am using a 1756-L63 control logix controller of firmware major revision 16 which is having a sercos module 1756-M03SE with same firmware major revision of 16.
Recently that sercos module got faulted so I changed with a 1756-M16SE with
firmware major revision of 19 without any changes..
Two observation I had made -
1. We can directly use a higher axis sercos card.
2. No firmware down gradation is required for firmware mismatch.
As in my case the running system have controller with major revision 16
and sercos card with major revision 19.
I thought that I need to control flash to match the firmware but it is not required...
So, any please put more light on firmware compatibility of sercos card..
