Allen Bradley Micrologix Controolers
Paul Sturgess
Feb 2014
Albany Georgia
I have several years in the DDC field of controls. I now work for a company that uses the above mentioned controllers. I have ordered the books from this website and am learning the ladder logic programming. The question I have is that, the have a system with a sensing probe and they want to remove it. They want to replace it with a scale (weight measurement) and use a 4-20MA signal. Can someone help me with writing the logic?
Greetings Paul ...
do you have the new scale's 4 to 20 mA signal already wired up to the controller? ... if so, post your ENTIRE program file (RSS extension) right here as an attachment to this thread and I'm sure someone will be able to help ... note that you'll have to zip your file before attaching it (forum rule) ...
Hi Paul, you should be able to see your analogue input inside your "I1 - Input" register under "Data File" file. Bring that address into a scaling function (SCP) to begin with and let us know how your going.
Paul,
Which model of Micrologix are you using?
The address format is different for these, from other Rockwell PLCs and when you look at the data table, it should tell you which are the analogue inputs are on the in-built processor.
I think even the default analogue inputs are 0-10 volts and NOT 4-20mA, as I had to use signal converters to get my 4-20mA to 0-10V.
If you use one of the I/O cards, then you can have 4-20mA or -10volts
SCP Instruction
How do I edit an SCP already in the program. I want to change it to a 4-20ma signal. I want it to cycle on at 250lbs and cycle off at 500lbs. Any help is appreciated.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
654
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,282
Hello everyone, So on Monday morning I'm expecting to have a box of random parts dumped in front of me. I'll create another thread with more...
1,979
Hey Everyone, We have a Micrologix 1400 (1766-L32BXB) with a Panelview 800 7" Screen, the Micrologix also has a 1762-IQ16 Input Card and a...
1,292
Hello guys, I just noticed that RS don't stock Micrologix output modules anymore. Is it true to assume that the Micrologix series is becoming...
3,460
