tranmeister
Hello,
I am currently using a 1794-IE8xOE4 Module with a 1794-TB3G Base for a project. http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1794-um062_-en-p.pdf
I checked all the wiring and communication of this module and made sure it was installed correctly.
There seems to be a issue where in the morning the module begans to fault. The only solution to this is unplugging and replugging the module and then all the normal operations will continue.
Do you guys have any ideas on what may be causing this issue? I also unplugged the module and replaced the module from another panel box. The same issue occurs in the morning. I only have to reset it once per day to have it working.
