Allen Bradley panelview 900, error 34.
davegsm82
Aug 2018
Newcastle upon tyne
A question for the hive mind, i have a Panelview 900, monochrome non touchscreen model.
On power up, i get error 34 which relates to an extended CRC check. I cant find any information about this error, however i was wondering if this is simply because the unit doesnt have any memory card fitted.
Does the PV900 series need a memory card or is the application stored on internal memory?
Thanks, Dave.
I have never had a memory card in any of the Panelview Standards I've had running.
99% of all mine have been replaced (upgraded) but I do have a few still running. Sounds like a bad screen to me. 34 I don't believe is a fault the screen is just not progressing past that point in the self test. Is the red light flashing or solid red
Solid Red = Static Ram Test Failed
Blinking (6 times a second)= Checksum Test Failed
Blinking (5 seconds on/5 seconds off) = Boot code incorrect for terminal type
If you mean the Real Time Clock Module I have never messed with one. Looking at Manual it looks like module has a battery in it if I'm reading it right. I will have to look at one I think I have old PV1000 parts if I haven't scrapped all. I think your unit is toast. What is full model number.
Yea the clock module has a very small lithium battery inside, if it fails then it cant keep time when powered down. Also the clock chip contains static RAM which again wont retain data when the battery fails.
I may have replacement clock modules kicking around, depending on the module number.
The PV900 i have is a 2711-k9c15.
Dave.
Hi Having issues with a older PanelView touch not working. Screen is connected to a Desktop computer. screen used as a display with touch...
116
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
213
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
734
Hello, I have several SLC-500 based systems. The user interfaces are PanelView 2711-TC1 touchscreens with firmware revision 3. I purchased a...
2,071
i was trying to run a .mer file which i have uploaded from a running pvp1000 same model. when i load it on new pvp1000 it shows " the terminal can...
2,250
