Allen Bradley PanelView 900
anchor93
Feb 2004
Can anyone please let me know where I can obtain the back light assemblies for the panel view 900. Seems to have a part number 77135-167-51 C
I guess only your AB dealer can help you on this. But don't be surprised on the price tag. It burned me once getting a replacement bulb for PV550.
Good Luck
Depending on the cost for the back light, you might consider the "Immediate Repair and Replace" program that AB offers. In this case, you pay a significantly discounted price and can have a refurbished PanelView (with a 1 year warranty) of the same model/revision that you are replacing. You will have 15 days to return your unit. Check with your distributor.
Marc
Adjust backlight
Hello.
Its posible to adjust backlight. Maybe you knov, but anyway, push arrow left and right for 3 sec. Follow then the menu.
Can anyone tell me if the AB Panelview 900 will talk with a parker gemini GV6 drive? I know the Parker uses ascii from motionplanner software. trying to use an existing panelview i have with a machine that has two parker gemini drives in it.
No, it won't.
The most generic communication driver the PanelView 900 ever had was Modbus, and those were very uncommon.
PanelView Standard terminals have only the communication network option they were built with; you cannot load another driver, and there were never generic or ASCII drivers for it.
Hi Having issues with a older PanelView touch not working. Screen is connected to a Desktop computer. screen used as a display with touch...
133
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
230
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
748
Hello, I have several SLC-500 based systems. The user interfaces are PanelView 2711-TC1 touchscreens with firmware revision 3. I purchased a...
2,092
i was trying to run a .mer file which i have uploaded from a running pvp1000 same model. when i load it on new pvp1000 it shows " the terminal can...
2,265
