Allen Bradley Pico question
redbagbruce
Oct 2008
Elkhart, IN
I'm trying to program a pico controller and need to span the analog inputs for temp (RTD) and ma (pressure transducer)so the the analog comparators can be set to proper temp and pressure settings. I have purchased a 1760 L12BWB-NC series A (has P buttons controlled by a rocker switch). Ideally I would like to adjust the analog comparator button with the P buttons. The picosoft program does not allow me to do this. Any suggeastions on how to do this?
Hi.
as far as I remember, when doing a compare, you can you a scaling value. I think you can use either a variable, or a timer/counter value. how about using a counter value, where 2 "P" buttons could be use to increase or decrease the counter's value ?
just a thought ... I can test it on monday !
Regards,
Jasmin
Thanks Jasmin, I opened picosoft and couldn't find a way to establish a scaling value other than the "0-9.9" default. Any help would be appreciated.
Bruce
Hi im trying to connect my pico to my laptop but I cant configure the com port for usb. it works okay on a different laptop with the serial cable...
2,057
I have a pico controller that i have to communicate with wonderware intouch. I wasnt able to find any server that communicates with the Pico PLC...
5,931
I have never used the Pico GFX, but I have been looking at it for a somewhat simple application. AB is hiding the programming manual somewhere on...
2,801
I have a skid mounted blower/material transport system that has one of these pico controllers in the panel. I really need to alter he programming...
6,116
Hello Everyone; Just purchased an Allen Bradley pico and was wondering if anyone could tell me what I need to order in way of software and...
3,715
