OK, I am trying to get thru all the informations that have already been shared - Thanks!
To Roy: I'm not new to process control, if only I was that far already! No I'm way below that, I too a class at the university some 12 years ago and haven't looked back since
And now it comes back to haunt me.
I most often deal with conveyor systems and packaging systems.
This system is designed to test the forces the wind will excert on roofing materials.
What we use is:
1. One large wooden box (app. 3,5x4,5x0,5 m)
2. One 22 kW motor/ventilator (that's not the right word! I'm looking for that thingy that sucks air out of a room/box)
3. One servomotor attached to a shaft with wings
The servo is then working as my valve, by positioning the servo in 0 degrees I can almost make my box airtight and thereby creating a vaccuum that will work as the wind forces om my roofing. By positioning it at 90 degrees the vacuum is 0.
The vaccuum I get from a differential pressure meassurement sensor and using some math I convert the value to kN/m2, as this is the value the user desires.
My "valve" can move at speeds up to 500 degrees/s, and this gives me an almost instantaneously force of 2 kN/m2 if I run the venting system at 50 Hz and then close the Valve. This of course is too much for the roofing and it will pop very quickly afterwards.
Now the system needs to go from 0 to say 0,22 kN/m2 in a maximum af 0,7 s (very little overshoot is allowed) and keep that for 2 s before returning to 0 and a rest period of about 2-3 s before starting over. And this is to be repeated 500 times for this value.
Next the value is encreased and the cycle is repeated 200 times. This goes on for quite some time, we expect the test to run over a couple of days every time we have something to test.
The guy who is to use the system, has tested it and found that if we start by 15 Hz on the venting system and close to 23 degrees at 70 degrees/s then after 0,7 s we change to 20 degrees at 500 degrees/s we will get the result needed (0,50 kN/m2)
But that's a lot of testing and work to be done, as this is not the only configuration we need to test. Therefore I would like to be able to use some form of automated regulating and just watch the value fall into shape.
So any advice is still appreciated.
regards,
Michal_dk
