Allen Bradley point IO flashes red. Won’t fire relay.
Bigtime
Jan 2023
Wisconsin
22
New to the ABpoint IO and have some experience with plcs but not that much. Anyway my question is why are these output cards flashing red? I am trying to fire a relay off one of the outputs from that 4th output card but when I hook up the relay the output I have it on (0). Goes dark.
436877AA-6562-4900-8563-B370E24C7E8A.jpg AD25C22C-3BE6-4411-9AC2-26E44446A36F.jpg
By default, Point I/O OB- outputs have open-wire detection enabled and will flash red if no load is detected. This can be turned off on a per-output basis in the configuration, but out of the box flashing red is normal for outputs with nothing connected.
It then goes dark because you have connected a load (and the output is not turned on).
I did not know that. Thanks!
Hello, I want to connect 1769 L18ER PLC with 8 number of 1734 pont IOs. 24V Dc 8 Channel Sink Input Module: 3 nos 24V Dc8 Channel Source Output...
7,704
Hi all, I’ve been asked about a project at work but given very little info. I’m somewhat experienced with Allen Bradley but far from an expert...
1,880
I want to test a small cabinet that includes a POINT IO unit type 1734-AENT. How can I test this unit if I don't have a PLC?
1,642
I have a PIDE set up for controlling a tank level. I've run the autotune on it and it is working fairly well except for one thing. No matter...
2,292
I have a 1734-oe2v +/- 10 volt card that drives a proportional valve. Its been in service for several years. today it quit outputting. The day...
1,754
