By default, Point I/O OB- outputs have open-wire detection enabled and will flash red if no load is detected. This can be turned off on a per-output basis in the configuration, but out of the box flashing red is normal for outputs with nothing connected.
It then goes dark because you have connected a load (and the output is not turned on).
