Allen Bradley RS Logix 500 Address/Symbol Database
henno2000
Jan 2007
UK
72
I have been asked to replace an existing AB control system with a Siemens S7 solution.
I have the AB documentation and am looking at specifying the amount of IO required.
I am not familiar with AB terms.
If possible, could someone translate what these address notations mean?
B
C
I
N
O
S
T
U
From using common sense, I can determine the input/output/counter/timer
addresses, but am unsure of the others. (I would assume that they are something like internal memory bits etc, but am after some clarification).
Regards,
henno2000
Thanks for the info.
I assume that the only external signals come from the inputs/outputs themselves? The others would refer to internally generated values?
Regards,
henno2000
Regards,
henno2000
That depends on what model of AB PLC you are using. For example, if you are using a PLC/5 and have analog modules then block transfers will be used to write the IO to/from integer (N) files.
Also, U is not a data file type. U is used to designate that the number following it refers to a subroutine number.
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
309
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
143
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
702
An issue occurred at an organization here in whereby the ControlNet card developed a fault. Card Details: Catalog/Series; 1756-CN2RXT B Part No...
454
Hey everyone, I have a problem that is the CROUT keeps faulting out with a "16#5003 20483 Feedback 1 and Feedback 2 turned ON (1) unexpectedly."...
1,324
