Allen Bradley RS logix option lost help
Jeff23spl
Jan 2010
Canada
860
Hello
This week i just lost the capacity to do Excel tag edit on my RSlogix500 soft. (I was using it few days before and the soft is installed for 5 years now)
At the same time i lost the capacity to see function bloc on my RSlogic5000 soft.
I think both need a pro license that i was suppose to have but i don't know why i lost both a the same time during this week when i really need it.
can someone have an idea on it ?
Yes, only the pro version of RSLOgix500 supports the built in menu option to edit with excel. Sounds like a license issue...
You can still use the database export to csv feature with the standard version. It just means a couple more steps to export...open the csv with excel...edit...then import.
RSLogix5000 also has different licenses to support the different languages and other features.
If you're using node-locked factorytalk activation, it's based on an encrypted key which is tied to either your hard drive serial number, or NIC card MAC ID.
Have you replaced the hard drive, or lost a NIC? Are you using a laptop with power options that may have turned off the NIC to conserve battery power?
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
284
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
135
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
652
An issue occurred at an organization here in whereby the ControlNet card developed a fault. Card Details: Catalog/Series; 1756-CN2RXT B Part No...
439
Hey everyone, I have a problem that is the CROUT keeps faulting out with a "16#5003 20483 Feedback 1 and Feedback 2 turned ON (1) unexpectedly."...
1,298
