Allen Bradley SLC 5/01
dijequeyo
Nov 2009
Maracaibo
Hi, i have a problem.
i don't have the cable to conect my SLC 5/02 with it's dh-485 port to the pc, but i do have the cable to connect other SLC 5/03 to my pc. my doubt is: knowing that my 5/03 has 2 ports, one dh-485 and one rs-323 and that the 5/02 has only one dh-485 port, can i connect a cable between both dh-485 ports and connect the pc to the rs-232 port in the 5/03, and program the 5/02?
You must use 1747-PIC or AIC+ cable and its RSlinx settings.
Cable should be around $60 but you can get "smart cable" for future RS232 connection of ANY processor
Although I have never done this you should be able to configure the SLC5/03 for passthru communication. See PDF's below for more info.
How far apart are the processors?
I am looking for the full version of the Software, thank you for your help
378
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,154
Hi all, Client has a hard faulted SLC 5/05 Revision B CPU, and I'm wondering if a Rev C or D can be directly swapped. Thanks!
1,127
Hello! We have a drum rotation machine controlled by a AB SLC 500. The drum rotation inputs comes from a encoder into a 1746-HSCE. We are using 2...
1,136
2,252
