I am using SLC 5/04 CPU (CAT# 1747-L542) with 1746 series I/O cards. I would like to replace only 5/04 CPU card with control / compact logix card. Give me your suggestion pls..
A major difference between using the 1747-AENTR adapter with SLC I/O
modules and any other Logix compatible I/O system is that the 1747-AENTR
adapter does not support a Rack Optimized connection type. This means that
each module is an individual connection to the controller. These connections
must be taken into account when converting the SLC controller. The main
considerations are the effect on the Logix controller's total number of
connections and the allowable RPIs to the modules in the 1747-AENTR chassis.
Originally posted by geniusintraining:
... but I am not a big fan of the card, ...
@geniusintraining
I am using 80 I/O's with this SLC 5/04 and 4 HMI's (Panel View 550 through DH+). Since PV550's are obsolete, I am thinking of replacing PV550 with low cost Ethernet compatibility HMi's. For this first I have to replace SLC5/04 with compact / control logix.
...they were told that it would "SOLVE ALL THEIR ISSUES".... it was hot, it stunk and scratching my head on Sunday at midnight trying to get things up and running before everyone started to show up...
@geniusintraining
Thx
