Allen Bradley SLC 505 and modem kit 9300RADES
kemppioy
Oct 2005
Dallas
72
Hello,
I have heard that there is a modem kit for the AB SLC 505 processor by the name of 9300RADES kit. Does anyone know how I can connect the SLC505 ethernet to a PanelView 550 that has an ethernet port and to the modem at the same time so customer does not need to remove the modem cable? Does the modem plug into the ethernet port of the plc?
Regards,
PK
The 9300-RADES modem has a built-in 4-port ethernet switch. You just connect the 5/05 ethernet port and the PV ethernet port to a couple of the ethernet ports the modem. For the dial-in, it has an RJ-11 phone plug. The kit comes with software for configuring the modem/switch.
I am looking for the full version of the Software, thank you for your help
374
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,152
Hi all, Client has a hard faulted SLC 5/05 Revision B CPU, and I'm wondering if a Rev C or D can be directly swapped. Thanks!
1,124
Hello! We have a drum rotation machine controlled by a AB SLC 500. The drum rotation inputs comes from a encoder into a 1746-HSCE. We are using 2...
1,135
2,249
