Allen Bradley UIC
Jezz
Dec 2002
Kendal
399
Hi All,
we were looking into getting a UIC to replace our old PIC but my supplyer say's
The unit is on technical hold by Rockwell and we do not know when they will become available at this time.
I was wondering if any of you guys knew any thing....
Jezz :unsure:
Eddie mentioned a problem back in December (THIS post), but I was able to purchase one a few months ago.
Mine works fine (so far). On 'Technical Hold' doesn't sound good though... utoh
beerchug
-Eric
I was told they have recall on some firmware releases, I think 1.1 is a problem, someone from AB please confirm.
I got some info: UIC on hold because firmware rev 1.1 has problem with some panelviews.
1.2 and 1.0 is OK.
It is possible all 1.1 units will be replaced with 1.2
Can't confirm this 100% but this info is close to be correct.
I have a AB 1747-UIC USB to DH 485 converter Can I use that to connect to a watlow controller EZzone with "standard bus EIA 485" ...
1,860
Having a bit of trouble getting my UIC working... using RSLinx Lite (don't have version number at hand). I have installed the UIC driver, but in...
1,479
i use slc5/03 1747-L532 .i communicate using 1747-UIC when i connected that device rs linx hang.i was try more times in more pc.1747-UIC LED not...
3,470
HI EVERYONE: help help help I did configure RSLINX AB_DF-1 and followed the instruction manual for 1747-UIC. Cable 1747-CP3 connected to slc...
4,194
369
