AllenBradley CPU 2080 MEM RTC2
Sep 2016
Jeddah
24
Dear all
Is it required power module after filling 4 cards as I am getting some error during compiling A power supply module is required within 4 slots on the left?Is there any way to solve without adding a power supply?
I assume you are using a Micro870 model controller?
These support up to 8 Expansion I/O modules but you must provide additional power after the first 4 modules to power any additional modules.
This is done by adding a 2085-EP24VDC Expansion I//O Power Supply...
You must provide a suitable 24VDC supply to this unit...
21.4...26.4VDC Class 2 or Limited Voltage Limited Current Source (LVLC)
I/O module capacity 4
Power consumption, max 24 W
Note: The 2085-EP24VDC Expansion I/O Power Supply is only supported by the Micro870 model controller.
Regards,
George
Hi there, I have an application where I’m required to connect Siemens S7-300 PLC (Profinet) to Allen Bradley Control Logix Remote I/O Rack &...
3,671
Does 1769-L33ER Allenbradley CPU has 2 builtin ethernet ports?
3,893
Hi guys, I have no experience when working with AllenBradley PLC, but I hope someone could clarify the result of multiplication shown in the...
2,214
Hi! It is always said, that DINT is the most performant datatype in AB plcs. I while ago i made a performance test. Several instructions like ADD...
664
