Alternate Instructions for DP Send & Receive
shashi616
Aug 2016
Jamshedpur
34
Hello All,
Currently I am migrating S7 300 to S7 1500 & I am unable to use DP send & receive data from Master PLC.
Which instruction is equivalent to DP send & Receive.
Thanks in advance.
You dont need to use DP_SEND or DP_RECV. In S7-1500 the DP I/O is part of the I/O image table, even if the DP Master system is connected via a CM1542-5.
If you have to read or write more than 4 bytes consistently from/to a particular slave, then you may have to use DPRD_DAT/DPWR_DAT.
And then you must specify the HW_IO, which is defined by the system when you add the slave to the HW configuration. You find it under the System Constants.
Thanks for your response Jesper.
I am a newbie to Tia.
What do you mean by " In S7-1500 the DP I/O is part of the I/O image table" can u explain a little more.
I need to log data from Profibus to a DB , & i am unable to find instruction to do that.
DPRD_DAT/DPWR_DAT doesn't assist in sourcing of data from Profibus to a DB.
Hello All, I want to publish my data in sql server in Excel format as daily report. And xl reported pro version seem to be much expensive which...
498
I'm looking for alternate module that I can use in place of Rockwell 5069-IO mainly for safety output card (OBV8S). Looking at the lead time, I...
1,206
Good morning everybody, I hope you are very well. I share with you the information of the PLC LOGO! Siemens and expansions that we have...
1,098
Hi guys Do you have some experiences with Power Analyzers such as Siemens SENTRON PAC4200?.. I have alternative analyzer installed on machine...
2,058
A while back I asked if anyone had an alternate security system for the RedLion Crimson 3.0 or 3.1, there weren't any answers, so I have done my...
5,737
