Am I being daft?
another workaround is this activex control which rotates Labels
Rotate Label ActiveX Control (v2.0)
http://access.mvps.org/access/modules/mdl0048.htm
works under Windows 10/64 with FTV 9
- To register a 32-bit dll or ocx Windows System file in a 64-bit version of Windows 10
1. Copy the RotateLabelVer2.ocx to C:\Windows\SysWOW64
2. Open a command promt as administrator, go to C:\Windows\SysWOW64
3. Run the command "regSvr32 RotateLabelVer2.ocx"
4. Now it says DllRegisterServer succeeded and it appear in FTV Studio
Great information!
Will this work on the PanelView Plus with the Windows CE os when created with runtime 9.0?
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
92
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
303
Software Ver. 22.00.00, After the 1st time of being true the EQL. instruction is still allowing the rung to be true even though the inputs are...
225
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
293
All, We have a site that has multiple Altivar 66's that are being controlled by an old Square D Modbus+ network. One of the VFD's has failed...
371
