Hello, I am working with the PLC connected to analog devices such as ball valve or pumps. the PLC is Siemens S7. the analog input module is S7-1200.
the problem is, the ball valve is not being controlled with the minor change. for example, when the ball valve is open as 12.5% and I tried to close it to 10%. however, the ball valve did not react. when I put 5% different as 7.5%. It closed it.
As it is, there are several issues about sending signals. what should I do to improve these kinds.
Please advise, thank you.
