Analog-Digital Card Q64AD Channel Problem
zai_jnr
May 2008
MALAYSIA
170
Dear members,
Now I'm working with Mitsubishi analog/Digital card with 4 channel. The system want to collect data from 4 level transmitter. For Channel 1 and Channel 2, I'm get no problem to receive data from level transmitter.
Got problem with Channel 3 and Channel 4 where I'm not receive any data from respective level transmitter.FYI, the system is 2 wire analog system.
Operation Voltage for level transmitter : 24 VDC
Reading Voltage check for channel 1 : 19.5~21 VDC
Reading Voltage check for channel 2 : 19.5~21 VDC
Reading Voltage check for channel 3 : 9~10 VDC
Reading Voltage check for channel 4 : 9~10 VDC
All channel I'm enable function using sequence ladder.
Any idea? Is it module card Q64AD faulty? But there have no error to the card.
Hello, I have a small programming task that I need help solving. I have to: * Create an analog input (4-20v)and a digital output * The analog...
45
25,281
I am attempting to interface a Mistras acoustic sensor to a AB Micro820. The problem I have is the sensor logic is 3.3VDC and Micro820 is 24VDC...
2,432
Hey I was wondering if you guys could explain to me how the signal flows on a analog & digital signal. for example: Explain the wiring of a...
2,203
Hi, I have 7 years of experience as a maintenance / PLC programmer in a fairly old steel mill. I was the one who converted PLC2 to CtrlLGx...
2,443
Hello, I was wondering if you guys could help explain to me how the wiring and signal on Digital and Analog inputs/outputs run from the PLC to the...
2,697
