Digital to Analog I/O
dlweber
Oct 2014
PA/OH
405
I am attempting to interface a Mistras acoustic sensor to a AB Micro820.
The problem I have is the sensor logic is 3.3VDC and Micro820 is 24VDC.
I will need one signal from the PLC to the Sensor and one from Sensor to PLC, (start / stop)
One option I see is connecting the 3.3VDC discrete I/O from the sensor to the analog I/O of the Micro820 has anyone ever connected digital I/O to analog I/O or have any insight on whether it might work?
I understand a relay would be the right way, however, finding a relay that accepts 3.3VDC on the control and mountable in the box is not straight forward and I do not have a 3.3VDC source for the contact side of the relay. The enclosure I have is small so I do not have room for much more components.
I might of missed them then I seen 5VDC as low end for relays.
The problem still lies that for the PLC > Sensor, I do not have 3.3VDC available to run to a relay to activate the Sensor input.
Their website says that all their sensors come in different outputs 0-10v, 4-20ma, 0-5, maybe you might want to check on getting a different sensor that will work for the equipment you already have.
Just my opinion.
The various voltages you are mentioning appear to be pertaining to the Sensors analog I/O ranges (-10-10V, 0-5V, 4-20ma), my issue is with the sensor's digital I/O, I am in contact with the company and there has not been talk of a 24VDC model. The I/O of the sensor is not as flexible as a PLC or other logic devices, there is very limited things you can do with each I/O point.
I had no influence on the parts that were bought, one of the other engineers bought it all and dumped in my lap to integrate. I actually fought against getting the Micro820 but ended up with it anyways.
They do have much larger more robust systems and I am not sure of the I/O capabilities of those, however, they are overkill and much more expensive.
^ I may be missing something but the part you linked to looks to be a device that interfaces the sensor to a PC or similar. I don't see anything about discrete I/O, nor could I find a wiring diagram on the website?
Edit: Is the I/O in that 9-pin D-Sub connector? Is there any wiring diagram or documentation you can share?
The USB does connect to a computer, it has a DB-9 connector that has 4 Analog in 1 Dig In, 2 Analog out, which can't actually be used for some reason, and one Dig Out the product bulletin on the right gives you some information the manual I could not find a downloadable manual, but it comes on a CD with the unit.
The RJ-45 connections are just links for cascading sensors
But regardless of pin out...the cable is already made and hooked up to the sensor unit. The issue is the 24V to 3V conflict on the Digital I/O.
I am wondering if I use the Analog I/O on the Micro820 to mimic the 3V Digital I/O on the sensor, do you think that will work? I never connected Analog to Digital I/O before and I can not find much information on it either.
Hello, I have a small programming task that I need help solving. I have to: * Create an analog input (4-20v)and a digital output * The analog...
45
25,165
Hey I was wondering if you guys could explain to me how the signal flows on a analog & digital signal. for example: Explain the wiring of a...
2,190
Hi, I have 7 years of experience as a maintenance / PLC programmer in a fairly old steel mill. I was the one who converted PLC2 to CtrlLGx...
2,421
Hello, I was wondering if you guys could help explain to me how the wiring and signal on Digital and Analog inputs/outputs run from the PLC to the...
2,685
Hello everybody. for an asignment we are using a s7 1200 siemens starterkit to connect sensores to create a program. we were hoping to save some...
6,519
