Analog Flow to Pulse output
We know little of the specifics, and even less of the accuracy that is to be achieved so it doesn't hurt to keep in mind a possible source for error.
Flow rate does not need to be "fairly constant" at all, it can vary wildly. The only consideration is how often you sample that analog, and that consideration can only be applied when you know all of the factors involved, most of which are outside the PLC.
The PLC can only process the data it is presented with, at a rate you determine, based on the capabilities of the hardware and software configuration the system is built with.
Sources of error can not always be eliminated, just reduced to an acceptable level, and that might involve some sort of filtering, smoothing, or signal rejection algorithm.
Precisely... however, the person asking the question wasn't experienced in integrating signals and everyone jumped in with a sample rate without knowing the specifics.
As far as we know 1 second may even be overkill, but we don't know and should perhaps leave the caveat that these things should be considered for the person that will implement them.
Given the variety of opinions about the wisdom and feasability of totalizing an analog flow signal I ran a test by totalizing both the analog flow...
3,428
Can someone tell me if this math function is correct to totalize analog flow in a 30 Milsec peridoc task...
1,739
As my confidence grows with working with multiple control systems, I am starting to take more and more on, where before I would just pie it off...
3,460
I have a Flow meter that returns a 4-20 signal and the problem I have is the pump is a diaphram pump so theres alot of pulsing causing my...
19
8,020
I've never programmed analog control in ladder. Here is what I'm trying to do. Flow 1 Analog input 1 - (4-20ma)0-50 lbs sec, this input is...
5,047
