steelblue48310
I'm working on a bench project to learn more about the basics. I have created a 'flasher' circuit with 2 timers, and that works. I would like to control the 'rate' of the flash by utilizing the analog inputs of my ML1100 (it also has a IF20F2 module)
I am thinking that the rate should be from once per minute to as much as 150 per minute, based on the 0-10 Volt input. I'm guessing that I would have to 'scale' the input with some math functions and such.
Also, is it possible to set one of the analog outputs to be a steady +10 Volts, so I can use that as my reference voltage for the potentiometer input?
Been reading, searching, experimenting... finally at a point to ask a question! Thx... Mike B.
