Analog Input PLC
Steve Cheung
Jan 2004
sgp
Hi friends,
Who know where I could find samples of analog input programs?
I have a project to measure the flasher rate of flashing relay by analog input plc.
Somebody could help?
Not sure what you're trying to do but if you wanted to know how many times a relay comes on or off I think you could do that with a discrete input. Use a timer and counter in your PLC to see how many times the relay changes state per time unit. Is this what you're trying to accomplish?
Think about it Steve - how could anyone satisfactorily answer a question so broad? I could give you analog programs that would be of no help - as a matter of fact I did one the other day on this site - search for MicroLogix 1000.
What PLC are you using? What kind of analog unit? Do you really need analog or a pulse frequency? What should your program do?
Is this a school project?
You have to do the hard work of clearly defining your situation and the logic and the parameters. Then we can help you.
Thanks guys,
I need to modify the data of the existing machine that PC base.
The Flasher relay signal is going to the analog input of the PC.
The relay must test by 3 kind voltage (11VDC, 12.8VDC, 6V) then,
the display will show:
Some sample of data that show at the CRT Machine as below:
TURN ON A DELAY A: 0.45 SECOND (DURATION WHEN PULSE ON)
TURN ON A DELAY B: 0.75 SECOND (DURATION WHEN PULSE OFF)
TURN ON RATE: 46.1%
TURN ON TIME: 84 SECOND
Turn On Time is: After 5 cycles of flash, measure three flashing cycle time (second)
Turn On Rate is: After 5 cycles of flash, measure three flashing cycle time(second) and current ON time (second).
I would like to ask:
Can PLC measure the Duration of pulse 0.001 second between on and off using analog Analog Input ? I would like to use PLC Mitsubishi A1SHCPU.
Hi all, I’m an electrician with limited knowledge of PLC circuits. Typically I will see simple 2/3/4 wire terminations for transmitters on...
26
1,269
Hi all, I want to catch min piks of an analog signal when digital signal is on(pls see the attached oscillogram). My hardware is 5069-L306ER CPU...
1,001
Hello I have a analog input signal that is bouncing a bit. The PLC card is a 1769-IF8 I changed the input card filter setting from 60hz to 50hz...
4,881
Dear all I am using delta AH530 RS- 2 cpu with devicenet communication and now I am getting problem while configuration of AH6xa-05 which is...
1,041
Hello everyone I got problem during practical. I am using delta plc model:DVP20EX00R2. Problem is that when i give 7v dc supply through bridge...
2,440
