Analog IO card from Siemens
Charbel
Jan 2012
Beirut
307
Dear,
I came across an analog card from SIEMENS to be used for transferring analog signals.
I couldn't understanding the cable length included on page 2/4 which states 200meters. I know it is better to ask Siemens about it, but if you have an idea, it would be great.
The input resistance as stated in the Analog input datasheet is 100 ohm and for example if I am using a flowmeter to be connected to this Analog input module say its load resistance is 700Ohm, so my understanding is that I have a margin of 600ohm (max) which I can use.
so for example if I am using 1mm2 with 17.2 Ohm/km, it really looks that I can use more than 200meters and I can reach 1000m cable (2000m back and forth)easily.
Appreciate any thoughts on this and if you can highlight any restriction that I am not aware of.
thank you,
Charbel
Hey guys! I have come across an unique issue. Hoping that I can find some solution here. I want to replace an existing S7-1214 DC/DC/DC plc with...
4,687
Hello Experts, I need your help about this issue of mine about my Siemens Analog Input Card SM331 having SF LED lit. I know this is system fault...
4,492
Hello, new to the forum, been here over the years on and off, but now I am more involved at work so I run into more difficult problems.... Maybe...
3,981
I want to control a rectifier output current by using Siemens analog output card SM332 so pls help in configuration of analog output card.
1,681
Hi all, I'm not a Siemens expert (my forte is AB) and I need a little help if possible. I have a 315-2 processor and one of my input cards...
5,212
