how to use siemens analog output card SM332
manoj.kumar
Apr 2010
delhi
I want to control a rectifier output current by using Siemens analog output card SM332 so pls help in configuration of analog output card.
So, we have one servovalve that is very critical to machine operation and idea is (or was) to detect if valve gets disconnected from analog output...
2,917
Hello everybody, I have a H_system including 2 CPU 400_H,3DI,1DO,1AO,1AI. Analog outputs are redundant. I used diode for redundancy purpose...
1,838
Hi Quick question. Is there 4mA at the output on the analog card when it is configured in the HW and the card has 24VDC? Or does the output have...
1,416
The noob returns! In the attached image, you can see where I've configured a remote analog output. Where I'm having a hard time, laughably...
1,514
So I am trying to control the speed of a motor with a Siemens S7-300 PLC. I have an analog input card as well as an analog output card. I am...
7,092
