Analog output Siemens S7-300 series
Ljohansen
May 2015
Odense
Hi
Quick question. Is there 4mA at the output on the analog card when it is configured in the HW and the card has 24VDC? Or does the output have to configured in the programming first?
Kind regards
Lasse Johansen
The card has to be set up as such in the hardware. It can be 0..20 mA or 4..20mA or a voltage signal.
Maybe you could elaborate a little bit?
If no value is written to the card in the user program, then the card will output what corresponds to 0 (zero).
That is 0 mA for a card configured for 0-20mA, and 4 mA for a card configured for 4-20mA.
So, we have one servovalve that is very critical to machine operation and idea is (or was) to detect if valve gets disconnected from analog output...
2,917
Hello everybody, I have a H_system including 2 CPU 400_H,3DI,1DO,1AO,1AI. Analog outputs are redundant. I used diode for redundancy purpose...
1,838
The noob returns! In the attached image, you can see where I've configured a remote analog output. Where I'm having a hard time, laughably...
1,514
So I am trying to control the speed of a motor with a Siemens S7-300 PLC. I have an analog input card as well as an analog output card. I am...
7,092
I want to control a rectifier output current by using Siemens analog output card SM332 so pls help in configuration of analog output card.
1,681
