Siemens Remote Analog Output Addressing
Jan 2015
Houston, Texas
31
The noob returns!
In the attached image, you can see where I've configured a remote analog output. Where I'm having a hard time, laughably enough, is how to address that output module in my program. The usual "Q1.0" isn't working.
I get the feeling I'm missing something super obvious here with regard to syntax. Any comments would be greatly appreciated.
In the topic header you write "analog output", but Q1.0 is a digital output.
Is the problem that you are using a BOOL variable for an instruction that requires a WORD or an INT ?
Also, in the setup of your hardware, you are starting on un-even addresses. Not sure if it is an issue or not, but one should use even addresses.
Thanks as always, Jesper!
Hello, new to the forum, been here over the years on and off, but now I am more involved at work so I run into more difficult problems.... Maybe...
3,980
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
582
Any manufacture recommendation for remote I/O for Siemens PLC.
2,916
Hi, I want to setup somekind of server in ALM so that I can start Tia portal on any connected PC and borrow the license automatically. Is this...
1,416
Hi, Here is my dilemma - I hope somebody has done this before. This involves equipment in three different locations (and countries). On site...
6,013
