Analog scaling siemens plc s7300
chama mulenga
Sep 2009
Lusaka
42
Hi all,
Does any body have some literature on how to scale the analog input signals e.g level tank control using a pressure transimmiter(4....20mA signal leadind to the PLC.)
Use FC105 from the Standard library (TI to S7 converting blocks) to scale the analog inpit, FC106 to unscale analog output. Place the cursor on the block in the library and press F1, the online help will give you all the information you need.
Hello, We monitor the temperature of a pipe via a 4-20mA temperature transducer. This goes into DB135(Read Analog Inputs). The issue I have is the...
628
I'm essentially new to Siemens (the last time I programmed one, the development app ran under DOS). I'm programming a CPU315-2DP in LAD. The...
5,276
Hi, I'm looking for a bit of help with a machine modification that I'm about to try. I am looking to control vacum pressure on a filling...
21
12,690
Hi all! I have a question about RSLOGIX and Analog input/output scaling So we have an existing controller with an IF8I and OF81 card. My...
936
I’m trying to perfect the HMI interface for analog configuration. I’ve provided the user the same options for all analog inputs, as follows...
1,675
