Siemens Step 7 Analog scaling
Gordo7777
Mar 2023
Scotland
Hello,
We monitor the temperature of a pipe via a 4-20mA temperature transducer. This goes into DB135(Read Analog Inputs). The issue I have is the transducer is slightly out of calibration I.E wAnalog_Value reading 87degrees and pipe is measuring 83degrees. In the Function block there is a entry rReplacement Value(currently zero). Is there a way to alter the rNormalized value ?
Any pointers would be of great help.
PLC Step 7 319-3
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
250
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
550
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
682
Please excuse the basic question, but I've never worked on Step 7 before (until now, only dealt with Mitsubishi Q-series PLCs)... What is the...
3,336
I really struggle with STL in Siemens Step 7 Classic. I'll learn chunks, but then I don't use it enough to retain and build on the knowledge. When...
17
3,219
