Analogue Input 12-bit resolution question?
russg
Aug 2012
UK
280
I'm just trying to get my head around how an analogue input with a 12-bit resolution is able to use the range 0 to 32000? Surely you need at least 15 bits to be able to achieve this number?
What am I missing?
458
Hello guys I am just wondering do I need to set up each channel configuration, including enabling the channel , ranging … if I have already...
2,034
Hi, I have a device which is giving out a 4 -20mA signal but the ADC's on the PLC channel do not match. The supplier is saying the channel needs...
771
Hi, I'm planning to install a new Analogue Input module Q68AD-G. It will inserted on Rack 0 Slot 4. When it's installed, will the code recognise...
2,444
Hi, I've got a Q68AD-G card (8 channel). I want to configure it for 0-10v analogue input. I've enabled the channel by using Un\G0. Then I used the...
1,851
