analogue output comms failure -timeout problem
manjit
Guest
M
Dear all,
I am using allen bradley plc 5/20 alongwith scada system of qnx windows as OS.when I am swiching on the power to the plc and pc (which contains the qnx software),it is continously showing the error of "analogue output comms. failure -timeout".I do not have a laptop to chk the plc program also.
can someone pls enlighten me as to what could be the possible causes of this problem?
manjit.
Hi Manjit,
It could be that whenever you boot up the plc looses some values,i.e you may have to condition a block transfer with S:1/15 (first scan of ladder or sfc)so as whenever you power up some data is written to your analogue output card.try this as i don't know much about the other hmi softare you are using.
That's a tough one. First, you need to find out what the heck triggers thr error message. You might find that on the PC if you have the development package for the software resident on the PC. Then when you find out what in the PLC triggers the errror message, if you've got a printout of the ladder, you might find the problem. But, I have found in the past, for the most part (99.99%), that PLC systems without programming terminals are unsupportable when you start getting "strange" faults. And another thing, anyone who expects you to support such a system without a programming tool has his head so far up his own arse, he will probably never see the light of day again.
r u right john
Dear john,
I guess u r right .I have trying to check out the problem thru the qnx scada software but i am also ne to the software and so till date have been unable to crack how the alarms have been set in the qnx software.also there is another point i.e when i switch off the plc ,the alarm still repeats ,so i feel that the error message must be generated from the qnx scada system itself and has nothing to do with the plc analogue outputs configured.
If anyone can throw some more light on my prob. pls feel free to vent urself ,as i might get a clue from it.
Thanks everybody
manjit
Hi All I was wondering if someone could help me with a question on the capabilities of modern PLCs and analogue output modules I am want to...
2,083
Hi, On line 964...Does anyone know what this TO command is doing? This is for an analogue output card Q68DAIN). R0S11 refers to rack 0 slot 11 on...
1,681
i am using a Q64DAN (4 channel Analogue out card) can someone give me some pointers on how to set it up and how to write to it. i have got it in...
1,445
Hello all, Just looking into a little error on a valve in our plant, the valve isn't reacting to signals. The DCS is calling for the valve to...
3,290
Hi First post so please be gentle. As part of our waste water treatment plant we use compressed air through a sparge to provide a supply of small...
3,120
