Angle display
JeffKiper
Jun 2006
Indiana
2,460
I have a bender that is a dumb induction motor running a gear back and forth to bend the material. The operator has a small tick mark that they bend to. They want a angle display. I'm looking for a stand alone display system. They move these benders with forklifts all the tiem.
I was thinking resolver or magnetic encoder but I haven't seen anything that would be an simple and easy for implementing.
For simple, could you use a potentiometer and a cheap panel display?
These "simple" projects always end up needing a controller. You'll end up calibrating the !@#$ thing all the time if you don't have an automated way for the operators to home it. Then they'll always be bending the homing prox mount.
Buy them an electronic protractor with a magnetic base. Mine came from Matco, but I'm sure there are cheap ones out there.
That Turck unit could work. I've used a similar device from Fraba on dancer arms.
I don't know why I forgot it, worked very well. You could parameterize it with putty or hyperterminal.
Then I would be thinking about something cheap and disposable. Google 'digital angle gauge'. The ones woodworkers use to set up saw blades are only about $30 to $50. I'm sure you can figure out a way to permanently attach it instead of the magnet.
-ERic
Guy you know sometimes the trees get I the way of the forest. That little digital angle gauge makes life simple. These benders are basically conduit benders.
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
147
More help again please... See the picture. I want to make the rectangle visible when Mr_Zr_ToggleSwitch is 1, and make it invisible when 0...
2,481
Anyone know what the little green triangle on SCREEN 3 means ? See picture Thanks
460
We have several S120 1FK7 axis controlled by an S7-1500T plc. Do we have some plc instructions to read the actual angle of all the axis at the...
792
I have 4 Altivar VFDs in my IO tree that pull data from the drives. 2 are tutrned off so have the little yellow triangle. Since these are added...
2,021
